Hei!
Myynnissä viisi kertaa ajettu semi-fätti.
Tilattu Wiggleltä 11.12.16
Kaikki toimii, en vaan saanut itsestäni irti talvipyöräilyä
Rungon koko : L (Wiggle sanoo 175 - 183 cm, minusta enemmänkin 180 cm ->. Itse olen 181.5 cm)
Rengaskoko : 27.5 x 2.8" ( tubeless ready )
Hintapyyntö: 430€
Yhteydenottotapa:
tuimasika AT gmail PISTE com
040 518 1993 (parhaiten klo 17 jälkeen saa kiinni)
t: Jussi Kauhanen
https://dl.dropboxusercontent.com/u/35529986/Cooker/IMG_20170227_004211.jpg
https://dl.dropboxusercontent.com/u/35529986/Cooker/IMG_20170227_004557.jpghttps://dl.dropboxusercontent.com/u/35529986/Cooker/IMG_20170227_004051.jpghttps://dl.dropboxusercontent.com/u/35529986/Cooker/IMG_20170227_004121.jpg
https://dl.dropboxusercontent.com/u/35529986/Cooker/IMG_20170227_004225.jpghttps://dl.dropboxusercontent.com/u/35529986/Cooker/IMG_20170227_004641.jpghttps://dl.dropboxusercontent.com/u/35529986/Cooker/IMG_20170227_004658.jpg
Number of gears: 1
Front Axle Type: Solid, Nutted
Cable Routing: External
Model Year: 2016
Frame: Tange Champion no. 2 Cro-Mo frame, Eccentric BB
Fork Material: Steel
Fork: Triple butted rigid Cro-Mo fork
Steerer: 1 1/8" Ahead
Bottle Cage Mounts: Double
Front Derailleur Mount: None
Dropouts: Non-Replaceable
Wheel Size: 27Plus (650b+)
Wheelset: Charge looseball hubs laced to Charge SOAC 27.5 plus x 40mm rims
Groupset Manufacturer: N/A
Brake Type: Hydraulic Disc Brake
Brakes: Tektro brake levers
Brake Calipers: Tektro HDC-330 hydraulic calipers with 180/160mm rotors
Chainset type: Single
Chainset: Truvativ E400 with chainguard
Chainring Size: 32 Tooth
Chain: KMC
Bottom Bracket: Sealed Cartridge
Cassette: 18t
Handlebars: RaceFace Evolve 725mm
Bar Tape/Grips: Charge Square lock-on
Stem: Charge Lite 31.8mm
Seat Post: RaceFace Ride 27.2mm
Saddle: Charge Spoon
Tires: WTB Trailblazer, 27.5+ x 2.8", folding bead, tubeless ready
Pedals: Supplied with basic flat pedals
Warranty: “5 year frame warranty, 12 month parts warranty”
Fork Type: Rigid
